"HELP!
I have a Volvo Penta A
"HELP!
I have a Volvo Penta AQ231B engine on a 21'6" Renken boat. I dropped it off to the boat yard to have it's annual sea trial done and they said the motor was overheating. I noticed prior to dropping it off to the boat yard that the engine temp did climb to above normal with the water running to the intakes. I replaced the raw water impeller, thermostat and hoses. I ran the engine again this time in a large bucket of cold water and it did the same. I took one end off of the power steering fluid cooler and stuck the garden hose in it. I increased the rpm slightly and the water was sucked into the hose and the engine temperature immediately cooled down. I think that should give me a pretty solid finding that the problem may lay in the outdrive drive and not the engine. The gooseneck hose looks fine between the transom and the lower unit from a visual perspective. I stuck the hose in the other side of the goose neck and flushed the lower unit. I noticed alot of brown and black stuff coming out of the lower unit.
Any ideas or am I chasing my tail.
HELP!!!!!!"
"HELP!
HELP!!!!!!"
