I have a volvo penta AQ170 wit
I have a volvo penta AQ170 with a 280 outdrive on a 22ft fiberform. It is a fairly heavy boat of course but it will only get around 16 mph at 4000rpm. I have a 15in 17 pitch prop and by my calculations I have a lot of slip going on. My outdrive says "D" at the end of the serial number which makes me think it is a 2.15:1 gear ratio. I need some advice on prop selection as my current prop started to give out last time out and needs to be replaced. I have not pushed the power all the way up to see how much is left at the top end but there seems to be a lot of throttle left. Also what rpm should I be running the engine at? 5000 is the limit but what is a good rpm for cruising out to the fishing hole? Thanks.....
