Volvo penta AQ131D Backfires on throttle
rdengil1
"Checked everything, the timin
"Checked everything, the timing is 6 degrees, the strobe timing advances to 32 degrees at 4200 rpm. Accelerator pump works fine. Plugs are gapped correctly and as far as I can tell my points are as well. They are new as well as the condensor and plugs. I do not have a fuel/water separator on the engine, just a clear fuel filter, I noticed a small amount, probably not more than a few drops of water and some sediment in the fuel filter, could this cause a backfire when pushing the throttle? If I push to full throttle, it goes. when at idle, its fine, only when I try and move to about 2-3000 rpm. Thanks. Dennis"
"And, did you check the advanc
"And, did you check the advance weights and springs inside the distributor as I suggested in my last post on your previous thread?"
