Hi
My husband and I are new to boating and this forum and are looking for a little advice and help.
We purchased a 1987 Bayliner Capri with a AQ131A -275 4 cylinder.We got it cheap but knew it would need some work. Floor and transom is good and boat is in good shape. The motor when running sounds rough. Had a cylinder leak down test done #1 86% #25% #3 75% #4 32%.
Also Compression test is 145 PSI dry and 245 PSI wet. Mechanic states leak is mainly going by rings and can hear it come out dip stick as well.
Now he also states that the timing sounds wrong and that could be the problem or rust in the cylinders. My husband is handy with car motors rebuilding and such and is going to see what he can do himself on this motor.We are looking for some help on where to start. Any help would be greatly appreciated.
Many thanks in advance
Tina
Tina
