"I think that might put You cl
"I think that might put You closest to the recommended rpm range. But as I mentioned, there are different 'kind' of props. Volvo Penta have 'STD' (standard) and HS (High Speed). I preferr the HS prop in Your application as the STD props are mainly for barges and displacement/house boats. Problem is they do not make 15 x11 in HS only STD. The smallest HS is 15x15. If You have a prop shop, or the dealer might help You, buy a 15x13 and if too heavy, have it down closer to 15 X 11. The 15 x11 will probably max You out at around 15 knots (17 miles), 15 x 13 19 knots and 20+ miles if Your engine handles it which I doubt."
