L
Lee Walters
Guest
"The Tach on my Starboard engi
"The Tach on my Starboard engine has started to run erratically the last few trips. Will read well at idle, around 800RPM, but as I open up the engine to trolling speed if bounces around between 1500 and 3000 RPM. It will then sometimes resolve and work well for a while, then start bouncing around again throughout the day. Engine is running smoothly a consistant. The altnators were replaced in June, and are charging. could this be just a bad connections or a actual problem with the tach?"
