"Please provide your technical
"Please provide your technical expertise regarding the bellow problem I face.
We have replaced High pressure fuel pump, cleaned injectors and throtle body, new spark plugs. At 2400 rpm the engine cuts off. This happens when the engine has reached operating temperature. I monitored the engine with the flame arestor out, when 2400 rpm are reached the left injector (viewing the engine from front side) stops to inject fuel, we connected the leads of the right injector to the left one (that is both injectors working with one power supply) and the engine operates relatively ok (not cutting when the 2400 rpm are reached).
Any hints of what is going wrong?
Thanking you in advance."
