Volvo Penta 5.0L Engine Block Swap
Dave Esser
I have a 1996 Regency Intruder with a 5.0L Penta engine.Unfortunately the water pump went out and I ended up with a cracked block. I have a Ford 302 crate motor, can I swap out the block with the Penta motor?
Yes, purchased for a mustang.....
Ricardo Marine, any ideas on whether I can swap parts on the 5.0L?
the Marine version was typically the Windsor. So if both are the Windsor models, yes.... all should swap over.
However, the automotive engine for a Mustang may not have a Static Compression Ratio that is suitable for Marine use.
The camshaft profile may also be incorrect for Marine use.
The automotive head gaskets are not suitable for a Raw Water Cooled Marine engine, yet they will work if fitted with a Closed Cooling system.
