tyeefisher
"1992 volvo penta 4.3l with el
"1992 volvo penta 4.3l with electronic ignition and a quadrajet carb.I am having problems after she warms up to 180 The boat will run for 1 min then completly shut down.I sounds like a fuel problem.I replaced the elec fuel pump and check the h20 seperator filter and no h20.I pulled the filter in the carb and clear.I checked the 1 way valve in the fuel line that is located before the filter and fine.I put a spacer under the carb incase of vapor lock issues.This problem only seems to happen after the motor is warmed up.Does anybody have any suggestions for me.Thanks,Jeff"
