rholling424
Gents,
I have a 1998 Four Winns 180RX with a Cobra SX outdrive. In 2003 I replaced the original carbureted engine with a new V-P fuel injected 4.3L GXi-D. It has run strong until last summer when it began running hot. Over the winter I replaced the rubber impeller which showed no wear and the thermostat. It runs at a steady 170 degrees up to 3000rpm. If I run above 3000, the temp runs away to 200, 220 and overheat. Can you help with this one?
Thanks for your help, Holly.
