Volvo Penta 3.0L GLP-E Outboard won't idle
TBriglin
I have to prime the motor by pushing the throttle forward 3 times to get the motor to start, and it does start...but I have to immediately move it into reverse or forward to get going otherwise the motor dies. It won't idle with the throttle in neutral. If I'm going slow in a no wake zone, I can keep it from dying by giving it just enough throttle to not produce wake, and to not die....but I'm trying to figure out what I can do to adjust the idle. I don't believe I have a fuel/water separator which is what I've read others suggest for other boat motors as a possible issue. I don't believe it's the spark plugs because once it's running, it runs just fine. I also don't believe it's the fuel pump because again, once it's going....it runs no problem. I'm not a marine motor mechanic, I was an Army tank mechanic though so I understand how engines run....at least on land. Anyway, it's literally only the idle that I'm having trouble with. Does anyone have any suggestions?
Ethanol can produce carb fine jet clogs that won't respond to carb cleaners, only to mechanical removal... i.e. a very small # series drill or wire. Alternatively ( so I've been told) an ultrasonic cleaner bath.
