Hi
I have a Glastron 175 with a Volvo Penta 3.0 GLP-E. We've been using it a fair bit in the early summer without any issue. Last weekend it developed an issue when we're trying to run it at 'high throttle':
Increasing throttle even more will increase the revs (although less than usual) but after ~20s the engine will begin to sporadically drop in revs in a pulsing fashion, and after a while it will completely choke and stop. At this phase it is possible to prevent the engine from dying out by throttling back. The period-before-choke seems to become shorter the more throttle we apply.
We've also tried to do a 'waterski' start where throttle is moved to full from an almost standstill. The boat seems to get going as it usually would, and the engine does rev up (although perhaps a bit less than usual). After the same ~20s it starts displaying the rev drops leading to engine stop.
I've talked with their local dealer, and their initial thought was that there might be water in the gas. Today we tried mixing in some additive that was supposed to help, but it did not result in any changes in behavior. I've ordered a new fuel filter / membrane as a 'blind attempt', as it has never been changed while I've had the boat.
Any suggestions on what might be wrong would be much appreciated
Edit: Could not get forum image insert to work, so I've uploaded a picture of the engine here https://pasteboard.co/IlolQ9G.jpg
- Engine starts as usual
- We can run at sub-planing speeds indefinitely
- We can give it a bit more throttle and get on the plane. It also seems to be able to maintain this 'just enough for planing' speed - although I think it sounds a bit more 'loaded' than usual.
- When increasing the throttle in small increments the engine will very briefly rev up, and then seem to return to the previous rev level
