Whitetailtime
Hello Board. I have to say I've been reading your boards for a couple years but never posted. I wealth of knowledge here.
First off I am by no means a mechanic.
This is year decided to replace the points in my Volvo Penta with a pertronix kit.
the boat ran ok before but was hard to start cold and a real pain. Up to speed no problem.
After a few mishaps on the installation I got the unit in and it fired up great. Sounded better than it had ever in the past on idle and low speed.
It was backfiring through the carb at higher rpm.
I checked the timing and it was off quite a bit but set it to 6 btdc as per manual.
It was smooth all the way up to 4000rpm
took it to the water and there was no top speed under load.
The boat would only chug along at about 3000rpm
checked the timing it was still good. But noticed when reving up to 4000rpm the timing mark did not advance. It remained at or close to 6btdc. The engine still sounded great though.
Now after a sllight slip checking plug wires I just installed
New plug wires
New ignition coil
i will be taking the boat to the water in the next few days.
My my question tho is why would the timing not be advance when checking it with the light?
I looked at the part diagram for the distributor and don't see any type of ad bar built in to it.
Please help
New plug wires
New ignition coil
Please help
