I am in the process of replacing the PDS bearings on my 290 DP drive. Prior to obtaining the new bearings I reviewed a lot of online forums related to their replacement. The general consensus for this was the I was going to need a 6007 and 6206 bearing along with a couple of new seals. I brought the old shaft and bearings to the bearing shop and told him that I needed a 6206 and a 6007 bearing, but he told me I was wrong. I ended up leaving there with a 32007 and 30206A (both are taper roller bearings). Please note that this is the same style that was originally installed.
Now that I am in the process of reassembling the PDS I have been doing some more research online and found that the taper roller bearings are usually not installed for this application. I see that there is only mention of using a radial contact bearing for this... but I did find an instance of someone else that looked up a volvo part # for their PDS bearings and found that taper roller bearings were used.
Here is the post related to that:
http://www.baylinerownersclub.org/index.php/forum/technical-discussion/54117-vp-dp-a-pds-bearings
My questions are:
If taper roller bearings were previously used, then wouldn't it be best to use them again.
What would be the advantage of used taper roller vs. radial contact.
When installing the bearings, there is a nut on the shaft which is used to pre-load the bearings. What should I torque this to?
My questions are:
