Hello all
I have just purchased a boat which is fitted with a D3-130
The boat is an Aquafish 23 (23 feet planning hull)
I noticed that while on the sea trial the boat performed well, even better than expected but only revs to maximum 3000rpm
At 2500rpm the boat gets up on the plain quickly and cruised at 17/18 knots flat out at 3000rpm she got up to a steady 25 knots which is, as ive been advised about spot on but the spec for my engine says it should rev to 4000rpm
It really makes no sense to me, all seems well, it purs like a kitten, doesn't seem in any way under stress, accelerates great, turbo seems to work fine, whistles like it should so I am seeking advise please.
The bottom is spotless, the engine has just been fully serviced it performs as well if not a bit better than I expected yet the rev issue confuses me?
I cant get any previous info as the whether it used to rev round to 4000rpm because the previous owner is no longer with us.
I did purchase the boat at a very very reasonable price.
One other issue, the diagnostic says there is water in the fuel yet I am advised by the boat yard that they have checked everything and that really isn't the case. Could that have something to do with the rev issue?
I haven't yet had the opportunity the run the engine up out of the water to see if it will then rev to 4000rpm.
That's about all I can tell you, any advised would be very appreciated.
