P
Paul Urbine
Guest
"I have a 2006 Chaparral 265 S
"I have a 2006 Chaparral 265 SSi wiith a 5.7 litre volvo penta engine. The oil pan has rusted through and there are two holes in it. It looks like the only way to fix this is to pull out the engine and install a new oil pan. This won't be cheap. Is there a way to replace the pan without removing the engine? Is the volvo replacement pan going to rot out in two years? Is there a way to prevent this in the future? The boat is always kept on a lift and covered when not in use. It only has 140 hours on it and is in the middle of its' thrid season. The only water that ends up in the bilge is rain water, and it never gets high enough in the bilge to touch the oil pan. Am I going to have other rusting problems? Has anyone else suffered from this? Nobody I talked to has ever even heard of something like this happening, but the dealer/mechanic showed me three other pans just like it with the same problem. What kind of marine engine manufacturer would produce something this inferior?"
