Finally Complete, all spacers will be machined from 3/4 round stock , 1 inch hose couplings/joiners/ splice .(3) , 6 hose clamps,
Dayco hose 71596 , original thermostat hose to pump is reversed and given a slight twist to join. From the original raw water inlet hose at the pump cut off the 1 1/4 end so its 3 inches long and save, cut off the 90 deg bend and discard, shorten the raw water inlet hose at #6 spark plug by removing 8 1/4 inches, and use hose splice to join and clamp.Install and clamp Dayco hose , install original thermostat hose reversed and join to Dayco hose with joiner/splice and clamp. Not shown is a ty-wrap holding the Dayco hose in place.,5th pic.
Power steering bracket lower adjuster slot cut and extended 1 -1/16 ,support plate on each side. Slight grinding mod to pump bracket to clear mounting bolt for plastic timing chain cover.
Mercruiser pully relieved to fit Volvo balancer snout, original nose bolt used with GM nose bolt washer.
1 inch longer manifold bolt and spacer for flush hose support.
