"Hi all,
I'm going to att
"Hi all,
I'm going to attempt to adjust the fuel injection timing on my Volvo MD11C engine (there is black smoke - injectors have been rebuilt recently) The manual says "Measure the distance from the timing gear cover to the base circle of the pump cam [the cam should be turned toward the crankshaft] Dimension should be 82.8 mm +/- .2 mm." I am not near the engine right now, but agonizing about these instructions - can anybody explain that more clearly? Also, once you have the injector pump out, you shouldn't turn the engine, should you?
Dennis"
I'm going to att
"Hi all,
Dennis"
