glaspar_aq171
"I am trying to get my AQ171c
"I am trying to get my AQ171c engine out of my boat so i can install another one. The motor refuses to come out of the boat. I removed all the bolts from the engine to the bell housing but was unable to get the shaft to come out of the flywheel. I removed the outdrive and took the 6 bolts out of the sealing ring (Broke 3 of them off because they are impossibly salt corroded in). Can't remove the sealing ring.
Short of using a saw and cutting the transom off the boat how do you get the dam engine out. Do I need to get a torch and cut the sealing ring off. I can't be the only one to have problems removing this poorly designed ring. I can't believe no one has ever invented a better method. It is impossible to get any penetrating fluid into the threads of these bolts. Are you supposed to just replace the Adapter every time you need to pull the motor. The book makes it sound pretty simple, remove the wires, remove the bolts pull the engine. They forgot to mention the hammering prying cussing for 24 hours trying to get it to break loose after you do that."
