I've been fighting trim sensor issues and now it has spread.<br>PO cut the plug when they replaced a trim sensor. I took it to a shop and they charged a fortune and told me they sorted the wires out. Sensor went bad again and i replaced it, making sure to match their connections. <br>It was fine for a few months, but then started sending random numbers to the digital display. <br>Last week, it didn't want to trim up, but with a little help, it went up. Now it won't go it. Down it fine, but up trips the breaker on the side of the engine.<br>i pulled the pump from the outdrive and put power to it - up and down with no problem. <br>I found the plug to the pump and separated it there. I read 12.7 or -12.7 for up and down. If i put voltage on the pump side, the pump runs up and down.<br>Reconnected and everything worked. Down, up, down up. Turned everything off, then back on. Engine relay fault - mid:128 sid:218 fmi:4 occ--- status. <br>Now trim doesn't work. <br>Any thoughts?<br>Steve<br><br>
