starsnstripes
I checked the coil, changed points, cap, rotor, plugs and wires. Still won't start. I have 12+Volts at the ignition switch. I could not cross reference a condenser to the cap, rotor & points that I bought. Just a hash mark. Just thinking that maybe the condenser was a specialty marine type item and the cap rotor & points I obtained at the local auto parts store were the same for automotive & marine. There was a [FONT=Arial, sans-serif]OEM 834560-5 Sierra 18-5348 from the Sierra website
[/FONT]
& the Volvo 841263-7 or without the -7...
I called the marina and they had one in stock. They looked it up by engine and when I took the cap off I couldn't figure out how it would fit inside. The Clymer book we have had a traditional points & condenser under the cap. The condenser supplied has a large mounting tab on the side and a lead with a double male spade connector.
I went to a friends boat. He has an aq151 which is very similar. He was also baffled that there was not one and remembered changing it but then said it must have been another boat.
. Does it have one at all?
Is it mounted outside the cap?
I'm getting spark to the cap but not to the plugs.
I read the 3 page post on compression and timing and will investigate that if after getting spark to the plugs does not resolve the issue.
I did feel the pressure of the #1 spark plug hole push my finger off.
Best Regards.
[/FONT]
Best Regards.
