starsnstripes
In troubleshooting no spark to the distributor on my AQ145A I went to test the coil cable to the distributor.
The coil wire tests over 11K ohms on an ohm meter.
What is an acceptable range?
It is too much resistance to use the standard continuity check on the meter. Had to change the range until it gave the reading. I noticed the parts store guy set his meter to the same continuity setting and said my cable was bad. I asked him to change the setting and then he got a high resistance reading. I asked him what it should be and he didn't know but I could tell from his past experience that this was a go / no go test.
I removed this and the longest plug wire and headed to the auto parts store. We opened several different sets and the coil wires were all too short and even checking a Ford 390 V-8 set the longest plug wire was too short.
The plugs that are on it are 7mm and don't appear to be anything special. The coil wire appears to be from a different set as it is black and the plug wires are gray.
After researching shopping options on the internet the Sierra brand is extremely expensive. Over $125 US.
Is there an automotive or other 3rd party cable set that will work that won't break the bank? I can even crimp my own if that is what it takes.
