Volvo AD41DP Oil Loss
"Hi, this is my first listing
"Hi, this is my first listing but I realy need some help. I have recently purchased my boat which is fitted with 200hp VP sterndrive. The first job we did was to change the oil and filter. Everything was fine until we slipped the boat, now we are getting oil spraying into the bilge from the area of the crankcase filter. The filter is clean but some oil around threads. As I work for Nissan we used Nissan 15W40 diesel oil. The engine runs superbly and never misses a beat. Any thoughts would appreciated"
"Thanks for the prompt reply M
"Thanks for the prompt reply MistaHays, this is very possible. I will check at the weekend and let you know."
"Thanks guys problem is now so
"Thanks guys problem is now solved.
Changed the oil and filter, used the correct oil and correct quantity. Runs like a dream."
"Looking at buying a vessel wi
"Looking at buying a vessel with a 200hp volvo penta, already has 1300hrs on the clock and wondering with the lower hp does this also bring down the rebuild hours down from larger capacity engines, basically how many hours are they good for before a rebuild.
some help would br much apreciated"
41 running at 3900 rpm at full
41 running at 3900 rpm at full load. 5000/6000hrs before rings?
