larrygaddis
" Has anyone seen this one? E
" Has anyone seen this one? Even though the temp gauge reads only 165 degrees F, the temp alarm on one engine goes off whenever I attempt to speed up past 8 knots. I thought perhaps air was getting into the raw water system whenever I started to plane, but I would think the temp would go much higher if that was the case. So far, I've changed the raw water impeller and the thermostats. I also checked the exhaust elbow and it's ok. But the problem remains. What should I check next? Thanks for any advise.
Larry in Honolulu "
Larry in Honolulu "
