Craig Stephen
Ok I am hoping some one can give me some light on an issue I have had this weekend with my Chris Craft Concept 25 with a Volvo 5.7 on DP
I spend 3 days at a lake, and covered around 30 miles both on the plane and on tick over. The engine run sweet as, no problems at all. On Saturday night we decided to stay on an island so ran in, anchored off and relaxed for the night. The next day I started her up, backed off and went out into the bay at tick over. On the way out I heard a bit of a grinding noise and thought I had clipped the bottom in shallow water but no mud was kicked up so trimmed up a bit and continued out to deep water. While waiting for my friend to get him self sorted and pull anchor I turned the boat off and bobbed around for 15 minutes. While waiting I trailered my leg to check my prop, no marks at all so I dropped it back down and waited for my mate to come out the bay, once he did I went to start the boat back up but got a terrible loud grinding noise on turn over so I instantly stopped. I checked connections and tried again, same issue so my friend towed me back ( around 2 hours back )
Once back in the marina we pulled the plugs and found water in the cylinders, strange as the boat had run fine but thought this could be to do with a bit of swell on the tow back, anyway we turned the engine over with no plugs in, she turned over fine. cleared all the water out, dried the spark plugs, put back together, only to find the same issue, loud grinding noise then after one or two attempts the starter just spinning.
Tried to turn it over with a bar, very stiff but does turn.
We pulled the plugs again, found no more water but misted oil in and turned it over, once again turned over fine with no plugs. We thought could be a bad starter motor, so pulled that and replaced with a new one, still the same issue so pulled the boat out the water and brought home.
Removed the leg once home to eliminate any possible leg problems stopping the boat from turning over under load so the boat is now at home, on trailer with no leg on but still has the exact same issues.
To recap
Will turn over with no plugs freely
put plugs in, will not turn over at all and a loud grind bang horrible noise
engine oil clean, full history with the boat, rebuilt 3 years 60 hours ago running perfect prior to turning it off while waiting for another boat to join us
Any help really appreciated at this point !!
To recap
