" I've got a pair of Volvo
" I've got a pair of Volvo 350's fresh water cooled. the port engine runs 160 degrees at idle or cruising, but heats up to 220 when I run between 900 - 1300 rpm. Pull the throttles back or push them foward and it cools to 160. New manifolds, risers, raw water pump, hoses, thermostat, checked the impellor, not clogged or damaged, installed correctly, pulled the heat exchanger apart and it looks good too. The starboard engine stays a steady 160. Any help is greatly appreciated.
-Aaron "
-Aaron "
