Hi
I have a pair off AQ140a Engines with a 280 outdrive. After a reseal and good pressure test, took the boat out. Ran good. Came back and oil had leaked from the outdrive. Came home drained oil (milky) Pressure?vacuum tested #$^& Good. Put thicker oil in it. Took it out, same thing. drained again and tested fine. Refilled and ran for a while in driveway. Outdrive to hot to touch( upper gear box. Took the dipstick out and milky oil was boiling out. It being in neutral, only the upper box was turning I am assuming the problem has to do with the box itself or the shimming. The drive was apart for a very long time and then may have been mixed up.
I am trying to check my shims with out a proper depth micrometer. I am over shimming and checking gap with feeler gauge. This should be an accurate method of measuring the total gap in the bearing house. The book wants 010 mm to be ADDED to this distance for the correct shimming. the box seams to me to be under shimmed.
My question.
I am correct then I am adding clearance for the bearing not loading it up by adding shims?
I was going to over shim this and put it back together and see if it heats up.
The box feels smooth and turns fairly easily by hand.
Any one have ideas on what else to check?
Thanks!
My question.
Thanks!
