"The factory gets a finite num
"The factory gets a finite number of cuts from a gear cutting tool before it is either re sharpened or replaced. So I guess if you were lucky enough to have randomly gotten a hold of a gear that was from that very same factory run, and of some twenty odd years later,
you'd better go to Los Vegas in a hurry.
If you are running a LH prop, then the lower driven gear is the one that takes this load.
What I'd have done (not that I'd even do this) would have been to move the top gear to the bottom (yes, those two are the same) and re-set the gear contact pattern.
Then, with the luck necessary to win big at Vegas, I'd place that ODD gear in the top position (the position that would give you reverse with a LH prop) and set the clearances and pattern!
It's a very long shot for something like this to work when mixing hypoid gears.
I'd not do this unless I had lots of free time and just wanted to experiment!
Now, here's my confession:
People ship these to me for repair if they are not in an area where anyone does AQ series work.
Some shops just refuse to work on them now days!
A man sends me his 275 transmission. He lost the brass split ring keeper on the vertical shaft.
When the keeper went, the vertical shaft went straight up and out the top cap!
Now I've repaired several of these from the very same failure over the years, and they can normally be very ugly after this happens.
So I ended up building him a transmission with a set of good used gears that I had here.
Shipped it off to him........ he was and still is happy as a pancake. All worked out well for him.
I ended up with his three remarkably good gears and remarkably good bearings, but gear cup had been broken off during this failure. Snapped it right off flush!
Well, I kept this gear set here for years thinking that someday, just for fun..... I'd find a gear that I just may be able to match up with the other two drive and driven gears.
Years later... probably ten years......, a man sends me another transmission... this was from a later C drive (larger bearings/different gear cut). He needed an assessment of the damage he had incurred.
In his box of DP C1 parts is this lonely 270/280/early 290 driven gear.... Just one, all by itself... bearing and all!
It had inadvertently been put in the box by the shop who pulled his drive apart and handed his parts back to him.
I looked at this lonely gear and I asked him what it was doing in with his C drive parts... he didn't know and apparently the shop was not missing one.
Well, I got him fixed up..... and he got the boat running again.
One day this lonely gear spoke to me and said; "Hey..... try me with that odd gear set over there!"
Well, I had an old gear case and I had that drive gear still in the bearing box. I had a good collar, so I stuck all three into this gear case.... spun it a little bit expecting to hear an unpleasant sound...... Hmmm, Sounds OK so far.
So I went a little further by starting out with a shim pack that gets me going when you do one from scratch.
Hmmm, I'm still getting a fairly good feeling set of rolling gears.
Now I grab my dial indicator, some prussian blue and get more serious and start going through a procedure.
Now, mind you..... I'm doing this just messing around and just for fun.... I'm not really serious, but more curious than anything!
It ends up the I got not just a good pattern, but a
darn good pattern with these three odd-ball gears.
It rolls nicely, pattern looks great, nice and quiet and rolls just as though these gears had been all born at the same time and place!
This transmission is still sitting on my bench, all ready to go, beautiful gear case, clean, good paint, but I just can't bring myself to sell it to anyone knowing that even while it all pencils out OK....... it just can't be right.
Someday I'll install it and see just how well it does.
There... that's my confession!"
