"Ron,
Be advised that there
"Ron,
Be advised that there may be more to it than the gills on the side. I'm not 100% sure, but, I think the 270 drive may also have a hole on the bottom of the drive in front of the skeg. This hole, if present, is also an water intake and requires covering when flushing or else you will not get suction. Check for this hole, and if it is there, ensure it is covered when using muff style flushers. In my opinion, the best way to flush is to submerge your drive in a large basin with a garden hose in it. I went the lazy man's route and incorporated a flushing system in my raw water supply line, with a quick connect for my garden hose, to both backflush and forward flush the drive, the cooling system heat exchanger and exhaust manifolds in my FWC system. Good luck... BZ."
