Volvo 230SP tilt motorpump
D
Donald Mitzel
Guest
"Recently bought used 89 Baret
"Recently bought used 89 Baretta Success that just needs a little TLC. Tilt did not work and I couldn't talk to former owner. Motor did work when I jumped it after disconnecting it first, but didn't raise unit. There is a small threaded nipple without a cap on side of pump/motor - is this where you fill it? Also, since it didn't work with the switch before jumping it, should I replace solenoid(s)as suggested by a website (there are 2 by this unit)?? FYI - I did try switch first and heard clicking, so power must be to the solenoid. Last question, what type oil do you use in this hydraulic system? Thanks, 'cause I plead ignorance..."
