Volvo 2002 Raw Water Pump Replacement
P
Paul Kowalski
Guest
"I have a question about insta
"I have a question about installing a replacement raw water pump in a 1985 Volvo Penta 2002 Diesel.
The old pump was leaking and so I decided to bite the bullet and replace the whole pump (I also ordered new pipe seals and o-ring)
Question- The Copper pipes (In and Out) of the pump appear to just "push" into the pump housing, with a rubber sealing ring on the pipe...no clamps, threaded fitting, or other stuff.
I can't see how this would be watertight - is there some sealant or liquid gasket I should apply when re-installing the copper pipes to the pump ?
Also - any tricks/tips to the removal/reassembly (eg: is getting the pipes lined a chinese puzzle ?)
Thanks for any info - I searched quite a bit before posting, and could not find this discussed anywhere."
Both pipes have straps that bo
Both pipes have straps that bolt onto housing holding pipes in place. Seal rings are lubed with soap and pushed into sockets. They will seal when installed correctly.
Thanks Dickv -
So it is rea
Thanks Dickv -
So it is really that simple ! Great news....I looked at it pretty hard and thought there must be something I was missing because most stuff around the boat has some odd twist to it ! Thanks for the info.
Paul
