Volvo 151 starting
navitec
"my vp151 turns over fine but
"my vp151 turns over fine but will not start or even try,when you let the key go and it returns to the ign position the engine will just catch and start any ideals???"
Mine was doing that. Check the
Mine was doing that. Check the coil voltage or battery. Do you have a resistor in series with the coil. I added a resistor to install electronic igniton and had that problem. Got a new coil with 3 ohms res and all worked fine
