It seems like my right of passage every spring to be contemplating or doing an alignment. It is literally the only thing I get help with so of course I need to chase the guy.
Last winter, I replaced all the mounts on both engines. The guy helped me with both sides and they were .003 or better. As soon as I splashed, I felt a vibration at low speeds on the Stb side, port was perfect. It was better at cruise and I just lived with it all season. I immediately thought alignment but a misfire crossed my mind. I even checked each plug wire with my timing light at the dock to make sure they were all firing which they were. I'll dig into this theory more...
I checked the prop for a bent blade and it's perfect. I didn't hit anything and because I used Prop speed, I would have seen something if I did. I can rule out dirty bottom or anything on the running gear because it was noticeable on my first run. Shaft was replaced a few years ago and was perfect the prior season. I checked the alignment and it's dead on. There' no binding, shaft turns easily by hand, cutless bearing is new and shaft is relatively centered on both ends of the strut.
My only complaint is I would like the shaft to be more centered in the shaft log, it's more towards the left hand corner. Shaft is not touching, I did check that.
What do you guys think? Can I rule out an alignment issue because I feel it at low speeds?
Bob
Bob
