eastcoastitalian
Hopefully maybe someone has had similar issues and can point me in the right dirrection. I have a 1986 merc. 9.9 (2stroke) i've acquired it about a year ago and i've never been able to get it to run properly. Motor is like brand new, fresh water use only,very low hours. I've completely rebuilt the carb, replaced the whole intake and reeds. All new fuel lines, compression is excellent. When i originally got the moter i determined the switch box was bad, it wasn't giving any power to the number 2 cylinder. Replaced with a used one, has good spark at both plugs now.carb is adjusted properly,problem is the timing. I can set the time dead on spec where the manual calls for,but it's not even close. It will idle pretty decent, but when i open it up just wants to bogg. But if i reach back by hand while running and manually retard the timing about half way, i mean i'm talking way further than the adjustment screw would ever retard the timing at WOT even if turned all the way in the thing runs like a scalded dog! I'm thinking maybe a faulty trigger assembly? It rotates smooth and easy, so any fault would be internal on it. Is this a symptom of a bad switch box possibly? It was used, so a problem is possible. But is this an issue the switch box would cause though? I don't have alot of knowledge on the switch boxes, this is my first mercury outboard, i'm use to my much simpler 4.3 I/O. Any idea's would be much appreciated.
