"Well, I think I know what my
"Well, I think I know what my problem is, but wanted to run it past some other "thinkers" and see if I could get some verification.
I've had this problem since I purchased this boat towards the end of last summer. The previous owner said it had just started happening the last time or two he had taken it out, and supposedly hadn't taken any action to try to correct or diagnose it.
Anyway... This is a Johnson 30 hp 1989 outboard.
Over the winter I rebuilt the fuel pump and carb, all the general maintanece stuff, replacing gear oil, impeller, lube, plugs, etc... Thanks to the help of you folks on here, I also was able to get the sync and throttle perfect.
Anyway, so here's the problem. I start the engine and it runs perfectly. If I go at a slow speed for a while and then open up the throttle the motor starts cutting in and out. It's not surging, cause it's not a slower pulsing. Basically no matter where the throttle is past about 1/4 she won't pick up any more. For a split second it'll pick up a couple hundred RPM and then immediately drop back down.
Anything below 1/4 throttle or so and it chugs along perfectly...
Along the same lines, if I start the engine and immediately take off, it'll run a good minute or minute and a half all the way up to full throttle. Then after a minute she just immediately drops back down to that cutting in and out.
In other words, once it heats up a little it will only run up till about 1/4 throttle.
Now my thinking is that it's a problem with one of the ignition coils. I'm thinking that the heat makes the coil "fail" and stop firing one cylinder.
My reasoning for why it still runs below 1/4 throttle is that the sparks are coming much slower and the coil can "keep up" if that makes any sense?
My only other thought would be the power pack. I'm guessing it could also be the culprit. There's two reasons I'm focusing on the coils. First, they're a hell of a lot cheaper! LOL... Secondly, considering where the mount, the coils get much hotter much quicker than I would think the power pack would.
Any thoughts on this would be great. If there's a high probability of it being the power pack rather than the coils I'd rather just get it ordered and be done with it so I can get it in place to test this weekend. Otherwise if it's most likely the coils, then I'd rather just order those and go that route.
Thanks again in advance for your thoughts!"
