jessie00721
Hello,
Im pretty new to messing around with verado engines and have some basic starting questions.
First: Can you make or buy a remote starter just to test these engines? If you can make one instructions would be great. (dont really care about shifting at the moment, just want to start it up).
Second: When you buy dts controls does a dts module hook up by the controls or in the engine compartment? Does that dts module need any kind of programming?
Third: I dont have any wiring at all as you can tell, where is the best place to get this stuff without spending a arm and a leg and is what exactly is needed to complete rigging? Different harnesses? Modules? Ect...?
I would appreciate any info you can give, I would be happy just to wire up something so the engine thinks it is in the run position on a switch so I can run diagnositc software at very least to start. If it matters, the engine in question is a 2006 275hp mercury verado.
Thank you for your time,
Jessie00721
Jessie00721
