Saltshaker
Hello, posting for some help on my velvet drives. Although I'm afraid of the diagnosis, transimissions just scare me.
I have '94 454 xl's, that are running pretty nicely. I have velvet drives, model 20-01-004. I've been noticing some ATF in the bilge under the port eng after running. I wouldn't say alot, but enough to notice it there. I also redid the port dripless shaft seal last year (norscot type so they use the same ATF) so there was some ATF leftover in the bilge on that side.
This weekend, before I left, I had a friend whos mechanical look around with me and things seemed dry. We put an oil rag under the transmission and after my trip, I saw there seems to be something leaking from the outboard (port side of the port trans). The boat ran fine, but I am afraid i some some sort of leak. I felt around again and it seems around where the trans bolts to the engine is greasy to the touch. I say that instead of wet as in dripping.
thank you
thank you
