Velvet Drive disassembly trouble
Pacemaker36
I started the teardown of my port velvet drive transmission (Model AS7 - 71C w/ 1.91:1 ratio) tonight and got stuck in a couple of places. It is a 1976 and it appears that it has not been opened up before. The snap rings are big and stubborn and despite owning a nice set of snap ring pliers they are too small. I have found some bigger ones and am ordering those.
The bigger problem is that I can't get the oil pump assembly (#40 in figure 8 of the manual) off of the forward & reverse adapter assembly (#45). Does anyone have any tricks or tips for getting it free? I've tried light force with hammer and screwdriver (as much as I dare!), Kroil penetrating oil, and a little (again as much as I dare!) heat.
I have the manual but it doesn't seem to cover disassembly... only assembly. Any help is greatly appreciated as I still have a second transmission to deal with too.
Thanks!
If the pump bolts are out, you should just be seeing the effect of the square sealing gasket. THese units are steel and iron and quite forgiving, so use a bit more force. Avoid sealing areas, but pry from the edge.
