bullet_bob
"Has anyone experienced electr
"Has anyone experienced electrical feedback problems with VDO tachs used on an EFI engines causing engine RPM's to vary.
I have 1996 twin Crusader 454 TBI engines with VDO Tachs and VDO engine sync gauge. My Stbd engine experiences problems only above 3050 RMP's exactly. I could run all day at 3050 or lower, but as soon as I go over 3050 my stbd engine will intermitently loose 300 rpm's exactly; no matter what RPM I am at above 3050. My mechanic seems to think that the problem is in the gauges. If I disconnect the sync and both tachs the boat runs fine. I have tried disconnecting ALL combinations of sync and tschs with no cure. The only positive response is when I disconnect all three gauges.
I don't want to spend the money to buy three new instruments if there is a work around to this problem"
