Hoping someone on this forum might be able to provide some advise. Is checking the fuel pump filter a simple process of dropping the VST tank, inspecting the filter, cleaning or replacing the filter? Are there other VST, fuel pump or float parts I should check while the tank is removed? (Are there other parts I should be prepared to check and replace?) Any advise in this regard would really be appreciated. Thank you, BlackMoon
