VacuumPressure Signal and VRO Pump Operation
captnemo
"Hello All,
Newbee here but
"Hello All,
Newbee here but have been reading topics with much interest. Seems to be a lot of knowledgeable folks on the board.
Let me first apologize for the long post.
I am working on a 1989 Johnson 225 VRO that I am trying to limp along until I can justify a rebuild or new motor (budget constraints). I recently bought this vessel and have been making incremental progress getting it seaworthy. I have disconnected the oiling system for now and run 50:1 in the tank as outlined in other topics. So far I have installed a complete impeller kit as well as two new thermostats. I installed a piezo buzzer from Radio Shack along with a momentary button that shorts the tan line to test for operation instead of buying the $50+ Johnson replacement.
It seems to have a problem with fuel delivery to the carbs. It runs fairly well as long as I pump the bulb. This motor has low compression all the way around as measured by an el-cheapo compression tester. All cylinders are within 10% of 75psi. I realize that this is a bit on the low side but it runs good enough for now as long as it gets fuel.
I have rebuilt the VRO pump with a Johnson kit but still have the fuel delivery problem. The old pump parts looked fine buy the way. I have cleaned the pulse limiter as per the factory manual and checked for leaks in the lines.
My question is what is the vacuum/pressure signal strength I should see at the pulse line powering the VRO pump for proper operation? Also what value of fuel pressure should I see at the main carb feed lines?
I am wondering if I have a leaky (seals) and loose (low compression) powerhead, I will not be able to make a strong enough vacuum/pressure signal to properly run the VRO pump. If I measure good number as suggested by you experts out there then I might go for a new VRO pump. I just want to make sure I don? spend the money and still have the same problem due to a worn powerhead assembly.
As a last act of desperation I am considering a small electric fuel pump powered through a relay by a signal from the rectifier/regulator.
I would install a diode between the rectifier/regulator red wire attached to the starter solenoid and tee into the red wire behind the diode so the pump relay would only be powered by the running rectifier/regulator voltage and not by the battery, which would now be blocked by the diode.
As an extra measure of safety I would put a kill lanyard switch and manual toggle switch in series with the power feed to the electric pump so I could easily kill fuel in an emergency.
I encourage your feedback.
Lou"
The crankcase compression nee
The crankcase compression needs to be looked at.My experience with the looper engines indicates that there are problems with the seal rings on the crankshaft.Electric fuel pump on an out board????.I would rather install a fuel pump or two from a v-4 of the 60's
