Both of my carbs are rebuilt and I've been tuning them on the hard. Timing is 10 degrees at idle.
Vacuum readings on both engines are in the 17-19 range but I can't get it to stay rock solid, there's a fluctuation of at least 1/2 on the scale. I would say it's more of a needle shake within that range, not really moving up and down.
http://www.secondchancegarage.com/public/186.cfm
It looks most closely like the example which references "high performance" engines with lumpy cams. Scenario #3 but readings aren't low but similar movement.
Do you guys find the same or can you get the needle to stay dead on at idle?
Also, did I read somewhere NOT to use the felt gaskets under the flame arrestors? The carb rebuild kit came with them, boat did not have them when I bought it but could have been long gone.
