knuckle47
Advanced Contributor
"I have decided to run a thoro
"I have decided to run a thorough vacuum study on each engine. There is no clearly defined access port on my 1992 engines other than a 3/8 pipe plug on top of the intake manifold 3" or so behind the carb. My plan is to remove the plug and adapt a tight seal to the gauge to obtain vacuum readings.
This port is not centered but I might think the vacuum should be distributed somewhat equally? Any suggestions about whether this would be acceptable?
vac
