"If it's working I would l
"If it's working I would leave it alone.
It is a gear driven system. The pump shaft has teeth on one end which goes into the crankcase and is driven by a gear on the crankshaft. So really, unless that gear gets stripped somehow, the pump should be "pumping".
Works almost identical to the waterpump (very similar design).
Oil injection gets blamed alot for everything that goes wrong with outboards and 99 percent of the time it can be tracked back to improper maintenance (and not of the oil system either).
I have a 1986 Evinrude with OMC's VRO oil injection, it's working fine and I see no reason to disconnect it. On the other hand, I don't think mixing gas/oil is a huge hassle either.
I guess it really comes down to "peace of mind" - some guys sleep better knowing that "they" mixed the oil/gas, others like myself, trust the oiler to do it's job (but to be fair, OMC does have an alarm that tells you if the oiler isn't working).
I still "personally" would trust Merc's system to the do the job - once I had confirmed it's pumping oil, of course..."
