This database of comments and fixes for outboards needs to be kept as clean as possible.
In other words, NO BS. The response about "the weight of the gas in the bowls" is so wrong it deserves to be removed by the mods.
Most people do not like it when I openly criticize posts. Sorry. So sad. flying's schooling on carb operation is just plain wrong.
Now, to show you, I will take you to physics school....:rolleyes:
Consider the bowl and nozzle extending down into it. Basically a bowl with a tube coming in from the top.
If I fill that with water, the level of the water in the tube will be the same as the level in the bowl.
You say weight of new water will push more water (or gas) up the tube. OK put more water in. Level at both points goes up.
Remove water. Level at both points goes down.
Ok, if I fill the system with ANY liquid...alcohol, gasoline, massage oil....the level in the bowl and tube will be the same.
Now consider a 5 gallon bucket. Fill it half way with water, gasoline, I don't care. Insert a clear, 1/2 inch id vinyl tube. The level of the liquid in the bucket and tube will be the same.
Using the same setup, insert an additional clear vinyl tube. This time make it a 2" id tube. Much bigger, much more fluid inside it.
The level in the bucket AND both tubes will be the same.
How can this be, when the "weight" of the fluid in the small tube is much less than the "weight" of the fluid in the big tube?
Add more liquid to the system. The level in all tubes and the bucket rises to the same point.
How can this be if "the weight" of the added fluid pushes the fluid up the tube?
According to you, it should take more "weight" to push fluid up the big tube vs. the small tube. But the levels remain the same???!!!! Whaaaattttt?
So, your contention that the weight of the extra gas in the bowl pushes gas up and out of the nozzle, with the opening of the nozzle being at least 1 inch above
the level of the gas in the bowl is ridiculous.
The reason the levels stay the same in both tubes and the bucket is that the atmospheric pressure on the open bucket fluid is the same as the atmospheric pressure on the open ends of the two tubes. The atmospheric pressure "pushes down" if you will, on all fluid surfaces, and the levels equal out to the same point.
AND THAT IS A FACT.
There is NO WAY the small extra "weight" of the added gas from a raised float can "push" the level of the gas in the nozzle tube up an additional inch to have it overflow.
So how does the gas come out the top of the nozzle tube? That is for another lesson. But you can school yourself!!
Google is your friend.
Google "venturi effect" and get the answer.
Just to help you wrap your mind around the venturi effect, consider the air to be the fluid, because it is.
Oh, and here is another twist on the issue....it is just about the same explanation as to why plane wings have lift, and can fly.
