hi all and gday
i am new to this forum and was hoping for some advice.
i have just purchased a 90 hp v4 cross flow of roughly 1984 it is already over sized and has had a partial seizure of the bottom right piston caused by running lean on that cylinder everything else is in really good condition.
i also have what i believe to be a 1988 v4 110 power head that is at the same size bore with only about 10 hours running with a rusty crank can i use the pistons and rods from the 110 and use them in the 90, and the exhaust on the 110 has a large power bulge whereas the 90 is flat would i benefit from using it as well and would there be any difference in carburetors
thanks
rod
thanks
rod
