V4 Carb jetting question
PhilSch
The V4 carbs have two high speed jets, one on each side. If you had a 67 on one side and a 68 on the other side would you basically have the same as two 67.5 jets?
Your motor is basically 4 separate engines with a common block and crankshaft.------Each carburetor bore feeds only one cylinder.----They do have a provision for balance across the 2 bores for idle air.
