I have a 1989 v200 BlackMax with wh-46 carbs. The number 6 carb is flooding out of the bowl vent at idle. I've rebuilt it several times, used a new gasket kit, clean every orifice with carb cleaner and compressed air. I switched the floats & needle valves with #5. Idles horribly and stalls in gear because of the flooding. Fuel coming out of the exhaust. Compression on cylinders 1-5 is 119-120. Compression on #6 is 110. I don't think that's low enough to cause this problem. Anyone have any suggestions as to what might be causing this? I have zero exhaust coming out of the prop hub at idle. 100% is coming out of the exhaust ports. Not sure if this is related in any way. Once up on plane it screams just fine. Thanks in advance for the help.
