the_tassie_devil
G'day all,
When using the available Flushing Adaptor kit that replaces one of the hinge covers on the Stern Drive, is one not supposed to run the engine when flushing out the Salt Water from the cooling system?
The reason I ask is that by running the engine, with the fresh water inlet bypassing the Water Pump in the lower part of the Leg, there is no water running through the impeller and therefore the impeller would be running dry, and eventually destroying itself.
Also, running the hose, without the engine running, there could be a ever-so slight possibility that any blockage in the exhaust system could result in fresh water backing bach up the exhaust and overflowing into the engine cylinders through open exhaust valves.
Thoughts?
At the moment, I am flushing the system by dropping the leg into a 100 gallon water tank, and this is wasting water as it needs to be drained often as it becomes saline with what gets flushed out every time it is used.
Thanks,
Bruce.
Thoughts?
Thanks,
Bruce.
