Used water cooled voltage regulator
J
John Daniels
Guest
Does anyone know if their is a
Does anyone know if their is any way to bench check one of these regulators to see if they are working correctly.
"There may be a test procedure
"There may be a test procedure in a SELOC manual. Why do you need to test it? If it is not charging, don't bother replacing it. Get a 60 amp single wire marine alternator, new belt and old bracket from a junkyard all for under $200. You may need an 8 gauge output wire for the alt. Somebody is selling the brackets on thie board."
